Anomalies in BRU-ANR-CRL-KJK-LGG-OST in 2024
Re: Anomalies in BRU-ANR-CRL-KJK-LGG-OST in 2024
sn26567 wrote: 25 Mar 2024, 15:38 This is rather an anomaly on Flightradar24:
Yesterday (24 March), Brussels Airlines resumed flights to Tel Aviv. Airbus A320 OO-SNJ operated flight SN3289. Flightradar24 data show that the aircraft diverted to Beirut. However, the same FR24 website shows that one hour after landing in BEY (?), the flight departed normally from Tel Aviv. Wow: teleportation!
Note: a Brussels Airlines spokesman confirmed that flight SN3289 landed normally in TLV.
Flightradar24 tracking disallowed ?
Post by DIBO »
While Flightradar24 is only guessing the diversion airport and in cases where ground receiver coverage is poor, that leads occasionally to incorrect guesses being made by FR24.
But in this case something else was going on. Once SN3289 was halfway between Cyprus and Israel, both FR24 and ADS-B Exchange received from SN3289 some strange ADS-B broadcasts (with position accuracy being reported as more than 10 NM = the worst grade of accuracy), with positions jumping all over the place.
And at the end of the flight these erratic positions reports, all centered (incorrectly) around Beirut airport.
My guess is, that the cause of all this can most likely be found on this map.
Egyptair Cargo flight MSR5567 from Tripoli (MJI) to Ostend (OST) operated by Airbus A330-200(P2F) registered SU-GCJ squawked 7700 while close to Nice, circled some time and eventually diverted to Milan Malpensa (MXP). After one hour on the ground, the plane resumed its flight towards OST, where it is expected to land at 21:48 (UTC+2)
sn26567 wrote: 28 Apr 2024, 21:41 Egyptair Cargo flight MSR5567 from Tripoli (MJI) to Ostend (OST) operated by Airbus A330-200(P2F) registered SU-GCJ squawked 7700 while close to Nice, circled some time and eventually diverted to Milan Malpensa (MXP). After one hour on the ground, the plane resumed its flight towards OST, where it is expected to land at 21:48 (UTC+2)
More information:
Last Sunday, an Egyptair Airbus A330-200, registered SU-GCJ and coming from Tripoli in Libya, was refused entry into French airspace by the Air Navigation Route Center (CRNA).
It was escorted by a Rafale, based in Istres, to the Italian border. The cargo plane was able to land safely in Milan, where it was able to refuel before leaving for Ostend in Belgium.
Established02
Post by Established02 »
Several diversions Wednesday evening due to thunderstorm over Paris.
AF A318, AF 320, AZ A319, U2 A320, AH B738, TAP A320, TU A320, AY E190.
Also OST got at least two diversions; 2x HV B738
Hainan 787-9 in holding above Antwerp:
https://www.flightradar24.com/CHH491/351fd921
nordikcam
Post by nordikcam »
Passenger wrote: 09 May 2024, 08:14 Hainan 787-9 in holding above Antwerp:
HU 491 diverted to FRA and UA 999 to LUX...
Airwave
Post by Airwave »
I suppose visibility issues, while in Antwerp the sky is clear ?
Airwave wrote: 09 May 2024, 09:51 I suppose visibility issues, while in Antwerp the sky is clear ?
Dense fog.
nordikcam
Post by nordikcam »
luchtzak wrote: 09 May 2024, 10:02
Dense fog.
I understand the density of fog but why is UA 999 diverted when just behind it DL140 lands...the airport has the same equipment for both planes...the two planes have different equipment?
ZavCity
Post by ZavCity »
Sunny now at home(Zaventem)!
nordikcam wrote: 09 May 2024, 10:28
Dense fog.
The only two flights that had to hold and divert are 78s.
Equipment / crew certification for CAT III?
Lux_avi
Post by Lux_avi »
Homo Aeroportus wrote: 09 May 2024, 12:22
Dense fog.
Yes, equipment related to the aircraft itself and not the aircraft type (the 787 is obviously CAT3 capable).
Or crew qualification indeed.
nordikcam
Post by nordikcam »
Thx for explanations ! Flynas from Jeddah was diverted too to MUC...and the aircraft was an A320 I guess ! It's staying in MUC for the moment !
Boavida
Post by Boavida »
A KLM A330 (PH-AKB) landed in BRU yesterday and departed back to AMS today. Anyone knows why?
https://www.flightradar24.com/data/aircraft/ph-akb
Tim Verheyden
Post by Tim Verheyden »
Boavida wrote: 18 May 2024, 19:45 A KLM A330 (PH-AKB) landed in BRU yesterday and departed back to AMS today. Anyone knows why?
For maintenance at Sabena Engineering.
KLM "often" sends A330s to Sabena for A-checks. They usually arrive on Friday, and depart on Saturday (roughly 24 hours per check). This doesn't happen every week, but quite often.
Groetjes, Tim Verheyden
https://www.jetphotos.com/photographer/266088
Established02
Sabena Engineering also seems to have a contract with KLM and Eastern for EMB175 maintenance.
Tim Verheyden
Established02 wrote: 20 May 2024, 00:41 Sabena Engineering also seems to have a contract with KLM and Eastern for EMB175 maintenance.
They do indeed. These planes get maintenance near hangar 8. The A330s get their A-checks done at hangar 117.
